Change TTL for a Domain
This is actually something that you can take care of directly in cPanel! Below are the steps you can follow in order to change the value for your domain:
  1. Navigate to your cPanel’s Zone Editor -
  2. Click Manage next to the domain you want to edit:
  3. Click Edit for the records that you want to make changes to:
  4. Change the TTL field from 14400 to your new value, and click save!
