Changing Domain's Nameservers within Client Area
If you would like to keep your domain registered with Reclaim but want to point it to a different host, you can change your nameservers within the Client Area.
From the Client Area homepage, select active domains.
Then on the right side click the arrow next to Manage Domain, then select Manage Nameservers
From there, you can replace Reclaim’s nameservers with those of your new host. Make sure to click Change Nameservers when you are done to save your changes.
