How To Sign Up For Reclaim Cloud
Hearing all this talk about Reclaim Cloud and want to sign up? Well, you’re in the right place!
Sign-Up
First, go to reclaim.cloud/signup
Enter your email to open a trial account:
Screen Shot 2020-07-29 at 12.56.53 PM
You will then be prompted to check your email.
Screen Shot 2020-07-29 at 1.00.58 PM
Activate Your Account
An email with the subject “Welcome to Reclaim Cloud!” will allow you to activate your account as well as provide you with additional resources available to you.
Create a password (at least 6 characters long, this can be changed easily later) and provide a mobile phone number for verification.
An activation code will be sent to your phone, and you will be prompted to input the code to continue.
Screen Shot 2020-07-29 at 1.05.19 PM
Get Started
After activation, you will be redirected to your cloud account and greeted with an introduction to Reclaim Cloud as well as an overview of how it operates. The final screen will prompt you to create an environment, which you can follow or you can exit out of it.
You can then explore as you like!
If you would like to learn more about Reclaim Cloud and what to do within your account, here is another helpful article.
Trial Account Limitations
During the free 14-day trial, your account will be restricted with the following resources:
  • 3 environments per account
  • 4 app servers per environment
  • 16 GB RAM and 51 GHz CPU (20 CPU cores) per app server or database
  • 1 GB storage per app server or database
  • Environment will go to sleep when inactive for 2 hours
  • Bandwidth is limited by 10Mb/s
Upgrade Your Account
Anytime during the 14-day trial, you can upgrade your account by selecting the “Upgrade Account” button at the top of your dashboard. You can also learn about pricing, the trial limitations of a trial account versus a full account, and see statistics on recent resources of what billing would look like with the environments running in your trial account.
