Installing Omeka S on Reclaim Hosting
Reclaim Hosting recently announced an automated installer for Omeka S is now available and in this guide we’ll show you how to install this new software.
To begin you’ll select All Applications from the Application menu in cPanel (note that Omeka S is different from Omeka Classic which has its own shortcut link from the Applications menu)
You’ll find the Omeka S installer located in the Content Management Systems section of the application directory (or you can search in the top right by name)
Click install this application and choose a location for the install from the dropdown. If installing to a directory like yourdomain.com/archive add the directory below the location, otherwise you can leave the directory field empty.
You’ll be asked to add the name for the install, Email Address, your name, and a password to configure the Omeka S install. Then click Install at the bottom of the page.
Once the install is complete you can use the /admin link to access the login for the dashboard of Omeka S and begin working with it.
