Logging in to WordPress
To login to your WordPress installation, start by accessing our client area at https://portal.reclaimhosting.com and clicking the cPanel link in the menu
Click My Apps to view your installed applications
The administrative link ending in /wp-admin here will automatically log you into your WordPress dashboard
You can also login to your WordPress install directly by typing in the website URL with /wp-admin on the end if you remember the username and password for the install you created at the time of installation. If you’re not sure what that is or you’d like to reset either of them see Finding your WordPress Password
Add a New User to WordPress Dashboard
Easy way to edit? Please say, "Yes"
