Reclaim Hosting's Nameservers
Domains registered with or hosted by Reclaim Hosting use the following nameservers:
ns1.reclaimhosting.com
ns2.reclaimhosting.com
Please be aware that changes to your nameservers can take 24-48 hours to propagate globally and improper settings can take your site offline for extended periods of time. When in doubt, contact Reclaim Hosting support in advance of these changes to make sure they are being put in properly.
Transfer Domains to Reclaim Hosting
Domain Mapping to WordPress
#2
Can you please tell me the next step:
I have my domain registered elsewhere. I have changed its nameservers to point to you.
What do I do next so I can use the domain on a site hosted here?
#3
Hi Nate,
At this point you should add an addon domain to your existing account if this is an additional domain (you can ignore the first part of the guide about buying an additional domain from us):
After that you should be able to use it with your existing account. If your existing account is using the domain you want to addon as the root account, you can just add it as an addon domain and it will resolve to public_html.
Let me know if you need any specific help with this, and I would be happy to help.
Best,
Jim Groom
#4
Thanks you.
I had searched the knowledgebase first but did not find that detail.
Nate
#5
Hope it works, and let me know if you have any issues.
