UpdraftPlus backup/restore with WordPress
Having your own backups is essential for any website, whether that be on or offsite. Aside from having automated backups, you also need to have an easy way to restore the backup if necessary. In this article, we will show you how to backup and restore your WordPress site with UpdraftPlus.
Creating WordPress Backup with UpdraftPlus
The first thing you need to do is install and activate the UpdraftPlus plugin.
Upon activation, you need to visit Settings » UpdraftPlus Backups page to configure plugin settings.
Settings page UpdraftPlus
Now you need to click on the settings tab.
This is where you will set up an automatic backup schedule and a remote location to store your backups.
First, you need to choose a backup schedule for your files, which would include your WordPress themes, plugins, images and other uploads.
After that, you need to select a backup schedule for your WordPress database. The schedule should follow the frequency that you make changes to your website.
UpdraftPlus settings
Next, you need to choose where to store your backup files.
UpdraftPlus allows you to save your backups to several cloud storage services including Dropbox, Google Drive, Microsoft OneDrive, any many others. You can also send your backups to an email address. All of these options are shown in the screenshot referenced above, and up to you in how you would like to proceed with setting up your storage location.
Creating Manual WordPress Backups with UpdraftPlus
Aside from having your backups being automated on the schedule you create, you also have the option of manually creating a backup.
First you need to visit Settings » UpdraftPlus Backups and click on Backup Now button.
Creating a manual backup with UpdraftPlus
This will bring up a pop-up with options to select files/database backup and whether you want to send the backup to remote storage.
Manual backup
Click on the ‘Backup Now’ button to continue.
UpdraftPlus will now start creating backup of your files and database, where you also will be able to view its progress on the settings page.
Backup Progress
The process may take a while depending on the size of your website, and will also send the files/database to your offsite backup location.
Restoring Your WordPress Backup with UpdraftPlus
Creating backups is easy, but the real useful part about backups is the ability to restore them with the same ease.
To do so, you need to visit Settings » UpdraftPlus Backups page and click on Restore button.
If you have saved backup files on your computer, then you can click on Upload backup files link to manually upload and restore them, shown in the screenshot below:
Upload backup files manually
Click on the Existing Backups tab and click on the ‘Rescan remote location’ link.
Remote backups
UpdraftPlus will now look for backups in the remote storage location and display them below. At this point, you will want to confirm the backup you are wanting to use, and then UpdraftPlus will ask you what you would like to have restored.
Restore options
UpdraftPlus will now fetch your backup files from the remote location and start restoring your site from the backup.
Backups are a great way to find that peace of mind when emergencies arise, and we hope that this article made it that much easier to set up the solution you were looking for.
